1 - 4 of 4 Posts
Administrator
eBay Motors: NEW 2008 CAN AM DS450 X ATV SPORT QUAD BIKE 4 WHEELER (item 230328470473 end time Mar-07-09 21:08:03 PST)
DS 450 X - Specifications
Engine
Type: 449cc, single-cylinder, DOHC 4-valve, liquid-cooled
Bore & Stroke:97 x 60.8 mm
Carburetion/EFI:EFI with 46 mm Throttle Body, 16 bit CPU with 32 MHz clock speed
Starting system: Electric
Transmission: 5-speed manual
Drive train:Chain driven/solid axle
Chassis
Frame:ALTEC dual-pyramidal aluminum
Front suspension type:R-Type Double A-arm, forged aluminum/Kayaba‡ HPG aluminum piggyback with adjustment for compression, rebound and spring preload
Front suspension travel:9.5 in (267 mm)
Rear suspension type:R-Type swingarm, cast aluminum/Kayaba HPG aluminum piggyback with adjustment for compression, rebound and spring preload
Rear suspension travel:10.5 in (267 mm)
Front brake:
Dual 182 mm wave type discs with inverted twin-piston calipers
Rear brake:
198 mm wave type rotor with single piston caliper
Front tires:
ITP Holeshot SR 21 x 7R-10 in. (ITP Holeshot SR 533 x 178R-254 mm)
Rear tires:
ITP Holeshot SR 20 x 10R-9 in. (ITP Holeshot SR 508 x 254R-229 mm)
Dimensions
L x W x H in:72.4 x 46 x 41.9
L x W x H meter:
1.839 x 1.168 x 1.064
Wheelbase:
49.9 in. (1.267 m) Dry weight:
345 lbs. (156.5 kg)
Ground clearance:
9 in. (229 mm)
Seat height:32.7 in. (831 mm) Fuel capacity:3 US gal. (11.5 L)
Features
Instrumentation:Low fuel, check engine, neutral
Lighting:Dual removable headlights
X package content available:Front KYB HPG piggyback suspension with high-speed & low-speed compression adjustments, Black aluminum rim with reinforcement rings, Aluminum handlebar riser, Aluminum taper-profile handlebar with square pad, Aluminum front bumper (number plate ready), Nerf bars, Chassis and swingarm aluminum skid plate, Quick-adjust clutch cable, X-package graphics, X-package seat cover.
Available colours:Black
I actually bought my 09 XXC from them. They gave me a heck of a deal on it too.
Saw that ad in Ebay. I was thinking about getting a left over 08 X model. I decided called up there to ask them some questions. Asked about an 09XC and they were able to get me a great price well under MSRP. Easily made my 5 hour drive up there worth it. They are a huge dealership though.
1 - 4 of 4 Posts
