1 - 9 of 9 Posts
ok i've been searching for 2 days before i finally decided to ask? has anyone replaced they're axle bearings yet if so a little help would be great? thanks
you can press the old ones out with flat head screw drivers. Since they are bad it doesn't hurt to destroy them. The new ones have to be pressed in. You can use a vise with some large socket wrenches. It is fairly easy. But if you have an 08 you might have a 3 bearing carrier. If that is the case I would buy a new carrier.
1 - 9 of 9 Posts
