1 - 2 of 2 Posts
So I just replaced my frictions, steels, springs, and clutch cable with OEM parts. I took the plug off the clutch cover and performed my adjustment there. The problem I am having is the clutch cable seems like it is way too long. I had to back off the adjuster at the clutch lever and loosen the adjuster on the cable itself to as far as it could go. Bike will slightly jump into first and wont go back into neutral when running. Is there a shorter cable I can get or am I doing something wrong? Thanks.
Discussion Starter · #2 ·
Any ideas? Any shorter cables out there?
1 - 2 of 2 Posts
