1 - 4 of 4 Posts
Anyone else had issues with coolant hoses or the tank itself leaking ? I just replaced my tank an there is still a leak from somewhere in the area where the hoses clamp to the tank istelf or one of them is got a pinhole ? Any info will help guys
have you checked the coolant nipple on the top throttle side of the cylinder head.
also if you run them gear clamps too tight you will deform the plastic nipples and it may be leaking there
I have so many problems with my cooling system my tank has a leak and my thermostat always comes off any one know how to fix that? i am getting a new tank and the thermostat housing is new can i not use the thermostat ?
1 - 4 of 4 Posts
