1 - 12 of 12 Posts
So I bought a intake ring awhile back and never got around to installing it. I knew I needed a larger filter so I bought a trx 450r UNI filter. However, it would not fit in my airbox. What filter do I need that will fit in my airbox with out modification? Thanks!
You'll prob have to cut the air box
Do you know off hand the part number? I'm not a fan of k&n's but if it's the only thing that will fit it will have to do. Is there a foam filter that will work for sure?
The honda filter does fit
this might also work for you UNI UAP-6400 4” I.D. X 5 ¾” X 7 ¼” LONG
if you get the BCS intake ring with K&N filter ( got mine from Ron wood racing ) there shouldn't be a fitment issue to my knowledge, haven't installed it yet but from reading it will fit but be tight, anyone please correct me if Im wrong.
X2 on the fuel customs yfz filter, and it does work i test fitted my buddy's off his 07, very nice dual foam filter. i ordered a durablue filter for a trx and no way would that fit in the stock airbox, had to use the kn that came from bcs
I did some researching and I went with a k&n filter with 4.5" I.D. and 5.5" long. That will get the job done
1 - 12 of 12 Posts
