1 - 20 of 24 Posts
Retired Moderator
Its really a pure race part . Im not sure you would get at lot of use out of it unless u are going to race
2012 AWRCS QXC-2 is the plan right now, got a lot to do between now and then, mostly surrounding the 50# I need to lose, hahahaha
i wouldnt worry about it...there are other mods (cheaper too!) that will benefit you more IMO
How is 35 bucks not cheap? Id just ask about the fit. Who knows thou might make it fit
it dosnt look like it would be hard to make it fit.
i don't think i need one right now but if i was going to a race were i expected alot of mud i would buy it!
$35 is cheap lol didn't check out the price. Go for it! Just save it for the muddy tracks cuz dang it looks goofy lol
yes I have one on my 09 x xc i like it i had to trim my plastic a little to make it fit the way i wanted it to but I do think it made a little difference in cooling not crazy amount but enough to notice and it doesnt look half bad either
didi you use it on the stock louver?
Discussion Starter · #10 ·
It would be impossible to fit onto the stock louver. A custom one has to be fab'd along with some mounting brackets for the louver.
FYI.. you can buy the outerwears material in X" x Y" sheets and make something on your own if you want. The one shown above ends up being like 45$ shipped. I've ridden twice now with it and the plastic has started to rub a hole thru it :(
I took the stock plastic radiator guard off and just mounted the metal v louver on
Nate 344 Do you have any pics of the grill that you installed. I know this post is over 6 months old but Im hoping to see some pics.
Thanks. I was looking at them and I seen that but I was just hoping to see the actual guard cause my nefew definately needs more than just an outerware ... lol
The proof is in the picture ... lol
With the guard you have to fabricate it out of perf. aluminum. And it's a good idea to mount a puller and pusher fan onto it.
Dirtracer,there was a thread about someone making a nice custom cover that you are looking for,with pics,hope this helps.
Discussion Starter · #18 ·
I purchased the outerwear bag and then started with a cardboard template to reverse engineer the actual shape and size of perforated aluminum I needed. I then continued using cardboard and some thin sheet metal templates to fabricate the mounting "louvers". I made mine similar to the warnert setup that bithell and McGill used.
Don't forget that you absolutely need a pusher fan mounted to front of radiator, behind the outerwears thing. You will need a custom mount for that, along with wiring and an on/off switch. This switch could potentially be the headlight switch if u are good with electrical.
1 - 20 of 24 Posts
