Can anyone tell me about the pink wire mod?? whats i actually do to the four wheeler? and if it hurts a warranty? and anything else??
I wouldn't do that unless I had a full exhaust or at least an slip-on on.... you will still run rich.you can cut the pink wire and run no baffle and air box opened. does not void the warrenty.
jus got mine 450x today..pulled baffel and airbox lid...where the hell is the pink wire located??pic!!youll be fine. pink wire cut, baffle out and lid off is a great set-up. you will not be too rich. when the wire is cut, the ecu is programmed to run with that set-up. you can add a K&N filter too and you will be even better off.
i would break ur bike in before cutting the pink wire. but its under the front plastics. sorta a pain to take of in my opinion but let me try and get a pic for ya
