Ok thanks and mod wise do you recomend anything else??? (Mainly for hair-scrambles)
I don't what level you race scrambles at but if your a beginner I'd think your good w/slip on, pink cut, lid off, we are regional pro and don't even run HC pistons on long HS since it takes the reliabilty down in long 3+ races....I'd think the closer you are to engine stock for HS scrambles up to the novice b class the better. If you find alot of dirt is clogging up your filter and box then protec makes a breather lid to keep dirt out....HS are more about reliabiliity and physical stamina vs power imo.
Run the louver kit some run a wire mesh screen behind it, ICE coolant, keep rad clean, replace all the BRP hose clamps, BCS has a coolant system mod that relocates the recovery tank away from the hot engine and adds a bigger fan always on that simplifies the system if you over heat on hot days. You can also rewirre the stock fan to head light circuit to keep always on or to the HL switch since it loads up the battery for starts. Get rid of the thermostat it's plastic and if it cracks or stays closed you done, replace w/a metal elboe from auto-store all it does is open at 70 deg F, remove it coolant always flows no biggie!
CV4 makes a fuel tank boot or wrap the bottom of the tank common to the engine with reflective heat tape, also the bottom of the coolant recovery tank common to the engine too. Also cut 2 inch diameter holes in the body plastic common to the fuel tank to get heat out prevent fuel boiling under pressure.
