1 - 7 of 7 Posts
hello
another question
nearly every heat i have to tighten the bolts of my rear sprocket.
does anyone have this problem too ?
i allready installed inox bolts with a blue nylon in it (don't knwo the correct english name) and i applyed locktite 243 bud still they keep comming loose.
i am now thinking about using bolts with finer thread M10x1 instead of normal M10x1,5 it should be better, bud i think it isn't normal that locktite doesn't help.
grtz
overtighten them. I had this problem the first few times I rode and had to keep tighting them but finally I got mad and just locked them down. They haven't came loose yet.
We had this problem several times ......
we had to replace the hub that the sprocket bolts to .
the race dept. sells a billet hub that eventually fixed our problem ..... but you must be using alot of torque to need this hub !
once the bolts get loose one time , the bolts bend the hub , they will never stay tight once they are run loose ..
Retired Moderator
Ahhh that makes sense , good bit of info to have
that makes sense, because my preveous can am had a lsr axle with other hub, and i didn't have the problem i now have on my xmx.
yeah same problem on mine... I just check them all the time
08 DS-450
Has anyone noticed after the bolts come loose that the chain now has a tight spot ? I think the previous owner of my 08 had them come loose and he rode it like that and it wallowed out the bolt holes making it have a tight spot ? Does this seem to add up I peeked at the swing arm bearing the carrier bearings and the counter shaft for movement and came up with nothing also tried two different chains this is my first post here don't tear me up .. tia have a great day
1 - 7 of 7 Posts
