well I guess tech its the final gear ratio, sprocket sizes. 14 38 would be higher than 14 front 42 rear.so the gear ratio means?
what tires are you running? i run stock gears with 18" rears and 5th has loads of torque, but on 20" 5th seems to lack any balls, yet its still not that fastThe 14 38 would have more top end but I wonder what would get there faster? the 14 42 stock or 14 38. I have a ron woods system and i have 15 42 which is fast down a road but cant pull 5th gear across a field. I was considering 15 43 and hoping to have a little more torque in 5th and get back a little low end power in the trails.
I am running the stock holeshots which are 20". I just got my 43 rear sprocket on today and its way better. I havent raced my brothers ltr to compare but I imagine I will be faster than I was. My max rpm with 15 42 was 80.7mph on a hard dirt road and I went by his ltr. I am guessing my new top speed is gonna be around 78 79 but I can shift into any gear and it pulls great.what tires are you running? i run stock gears with 18" rears and 5th has loads of torque, but on 20" 5th seems to lack any balls, yet its still not that fastThe 14 38 would have more top end but I wonder what would get there faster? the 14 42 stock or 14 38. I have a ron woods system and i have 15 42 which is fast down a road but cant pull 5th gear across a field. I was considering 15 43 and hoping to have a little more torque in 5th and get back a little low end power in the trails.onder:
What fuel system would you recommend upgrading too? looking to add bottom end without messing w any ecu's or i may end up having to get a dyno anyway. what fuel system do you recommend?Its nice to have a couple options IMO
Depends on your mods an riding style? not sure if you meant stock gearing or stock motor? If you have a motor that pulls good on the low to mid then you can gear higher. Even a full system can make a big difference. The ds450 stock does not have excess low to mid & IMO pulls better in the upper rpms. With the smaller rear tires you might be fine? Some times a front sprocket might be too much? I use to like to gear down more, but seems like you end up shifting much more.
I am running 14 front 38 rear but with oem hub not sure if you can run that. Sometimes feels like I could go higher, but also the motor I have is setup with lots of mid power so it works.onder:
where do you find a 43 rear? i can fin anything bigger then a 42. any links?The 14 38 would have more top end but I wonder what would get there faster? the 14 42 stock or 14 38. I have a ron woods system and i have 15 42 which is fast down a road but cant pull 5th gear across a field. I was considering 15 43 and hoping to have a little more torque in 5th and get back a little low end power in the trails.
What do you do for gearing for top speed? Looking to do a few road drags this summer with my buddies and then I'll swap back to MXCompared to my other quads the ds450 has super short gearing... So I would think it's good to go from the factory... But I race desert, not mx... So we need top speeds
