1 - 2 of 2 Posts
Hi guys, I'm installing a Trail Tech Vapor for each of my boys DS450. The wheel sensor, tack and power wiring are done, just the coolant sensor to do.
Any body can confirm which hose I should use for the temperature sensor between the one that goes to the top of the radiator and the second one that is plugged to the bottom of the radiator?
Thanks a lot for your inputs.
Discussion Starter · #2 ·
Finally decided to go ahead and put the sensor into the hot side (hose that bring coolant to the top of radiator) and think that’s the best choice.
1 - 2 of 2 Posts
